Amp Mounting Help
TomT
SoCal/OC
The shop that did my install used construction adhesive to mount MDF to the back wall then mounted all the amps and stuff to that.
Witch
Hemi 5.7 liter
You can make simple brackets out of perforated flat stock say 3/16" would be plenty strong
Then mount to seat bolts , where are you getting your signal from ?
autokraftgt
Hemi 6.1
Kinda like trout said, I would take MDF and spray with bedliner or some kind of protective coat (from water) and place MDF betweem your sound cancelling materials, and the factory carpet. Lay factory carpet over the MDF and then screw the amp down through the carpet into the treated MDF. It won't go anywhere. Protective coating on MDF is to keep wood protected from moisure if carpet/floor where to ever get wet.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
MDF under the carpet, screw into it through the amp and carpet. Might work?
worried it may swim around or get dislodged (ripped). I think I am going to pull away the 1/2 Dynaliner, and Dynamat on the back wall, and mount it there with Liquid Nails unless I can find a seltbelt bolt I can potentially use. I will post pics with the finished result. (Gotta finish my driver door Dynamat and Dynaliner first!).
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
The challenge is as much clearance as it is adhesion. Despite the small footprint, I may need to go to 1/4 MDF. Great ideas guys. Thanks!
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
This is exactly what I did. 1/2 in MDF, liquid nails, braced it over night. I cut away the dynaliner, dynamat and the factory insulation... boom. Fits so nicely. Thanks! :favorites13:
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Imgot my Stelathbox powered: beastmode. May do a different thread when the 16 ga speaker is all ran. Not looking forward to fishing the through the door boots.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Here is the link to the 16ga speaker wire re-run to doors. No cutting of the wiring harness required.
adurm
FL
2015 RCSB
There is a velcro strap for like $5 at home depot with both textures on one piece. Cut strips long enough to encircle the amp in a couple different directions. Then take another long piece and connect all that to the seat brackets. No drilling.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Tried it. The pic above has the H Depot velcro. It just didn't grab the carpet for me. I instead mounted it to a 1/2in MDF block of wood and then used liquid nails and stuck it to the back wall. Works perfectly and I don't have to worry about anyone kicking it under a seat. :naughty:
TomT
SoCal/OC
Or a spilled Big Gulp (don't ask me how I know).
moregrip
NO pics? sounds like she's coming along nicely!!
adurm
FL
2015 RCSB
I didn't mean to try and stick it to the carpet. I looped it around the amp then used a couple more strips to stick to the ones around the amp then loop around the seat base.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Here's what I ended up doing and it is working well. Pardon the wiring mess, still cleaning it up.
