metalmancpa
- May 9, 2017
- 110
- 31
- 2014
- Hemi 5.7
I have the stock 8.4" non Alpine system in my Ram. I'm starting the process of researching upgrades. Due to several factors, my first move will be to just replace the speakers. I've only researched briefly thus far, but finding the actual equipment doesn't seem to be that difficult. It will come down to brand choice, and if I can use anything coming out of my 300 just taken off the road. I already stumbled on depth specs for doors as an example. It's what I can do labor-wise to save a few bucks, though I'm nervous.
It appears that taking the doors off isn't that big of an issue. I looks likes four screws and a handle screw which I have yet to look at. I ordered on Amazon trim remover tools (really cheap), because that's the mistake I've always made when DIY'ing upgrades in the past. It's the speakers/tweeters on the dash that freak me out as I have never done dash work in a car. I cannot imagine taking off the dash myself. I've never heard of easy access to speakers in the dash so I am assuming the same level of difficulty with the Ram.
My plan is to keep the OEM head unit. I have a JL Audio Clean Sweep and Summing Unit in the 300 I am taking out. I have a couple of JL Audio Amps, a 500/5 coming out of the 300 (it's pretty big), and a smaller one out of a PT Cruiser (I forget the model but it drove 4 speakers and a sub in the PT). JL Audio has a nice single stealth sub to occupy underneath the smaller rear bench (although pricey), so that leaves me with underneath the larger rear bench and front passenger seat for the Clean Sweep, Summing Unit, and an amp. I also have a Monster Digicap I'd like to keep. I fear that to due install limitations I may need to get an amp that has a cooling fan due to tight install spaces.
Any advice and guidance would be appreciated. Just realize I am fearful installing an entire system myself as the wiring is complex, and coupled with the tweeters in the dash that scares me away of most DIY. I can't picture myself tearing the Ram apart and putting it back together. I used to have Tweeter Etc do my work until they went out of business. I would come into the shop and see the car in pieces and it always petrified me. I'm older now (57) and have lost some brain cells so my fear it would be a Humpty Dumpty experience if I tried it alone.
