Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Audio & Electronics
Audio & Electronics
Audio Upgrade & Modification Basics!
This is a discussion on Audio Upgrade & Modification Basics! within the Audio & Electronics forums, part of the 4th Gen : 2009 - Present category!
Car audio is not hard unless you haven't done it before. Here are some basics that may help: site for ...
Like Tree19Likes
Reply
Old 05-25-2012, 10:29 PM   #1 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Post Audio Upgrade & Modification Basics!
site for oem wiring: https://techauthorityonlinedemo.extr...rv1gp3bs674819
To start if you are installing a oem radio to replace your current oem such as raq, rec etc these are plug and play no further wiring is needed. Only thing that might be required is a different radio bezel as Chrysler Jeep Dodge makes one for the navigation and non navigation.
In regards to my gig that is considered a retrofit There are a few parts that cost anywhere from $200-400 to make this fit including a lock pick, nav antenna, bezel, Sirius antenna.
All necessary harnesses and installation kit for an aftermarket Head Unit (HU):
1. Peripheral's CHYAH05 or Pac Audio C2R-CHY or scosche CR03SR (lets you retain factory amp with your new head unit)
2. Wiring kit (allows you to bypass the factory amp to use the head units power) http://www.crutchfield.com/p_1207065...n-Adapter.html or Pac audio C2R-CHYNA
3. here is the antenna adapter from oem antenna end to the new hu: http://www.crutchfield.com/p_12040CR...r.html?tp=2569 or scosche CRAB
4. to retain steering wheel control on your aftermarket head unit you will need PAC SWI-X in conjunction with SWI-Can 2
5. If you decide to go with an aftermarket navigation unit and do not have an OEM navigation unit you will need a factory navigation radio bezel. If you go from a navigation unit to a regular Head unit without navigation you will need to get the factory regular radio bezel.
When installing the aftermarket amp, run your RCA from the pre outs on the back of the Head Unit to the designated amp. From Subwoofer pre outs to subwoofer amp etc. NOTE: not all amps have inputs for multiple power and ground wires.
Subwoofers:
1. Visiting audio shops listening to subs can be the most important piece selecting a subwoofer that will fit in a box that will fit in the truck.
2. Your subwoofer has some type of ohm configuration most common a single voice coil (SVC) 2 ohm or 4 ohm or dual voice coil 2 ohm or 4 ohm load (DVC). Knowing this is very important when deciding on an amp and woofer. NOT ALL AMPS are compatible with all ohm loads. Wiring the sub is more than just plugging it in from sub to amp and requires the decision of the ohm load you’re planning to run which is called series or parallel. When choosing an amp you want the rms and max wattage to be about the same as your subwoofers rms and max wattage. Amps are usually rated somewhere like this but this is an example of standard RMS ratings:
200 x 1 @ 4ohms
400 x 1 @ 2ohms
600 x 1 @ 1ohm
Ideally you want to maximize the amp to run it at 1 ohm. Look at the the link below to see what woofer configuration you need to get to those specs.
If you went with a (DVC) woofer you notice if you bought (1) 2 ohm woofer you could run it in parallel to achieve the 600x1 @ 1ohm from the amp. This is a simple representation obviously you can add multiple woofers and obtain different ohm loads. BUT REMEMBER NOT ALL AMPS CAN HANDLE ALL OHM LOADS A LOT OF CLASS D (subwoofer amps) are not 1 ohm stable, so be sure to look at all specs of subwoofer and amps, when deciding on the package you want to buy.
Installing an aftermarket amp and subwoofer with a OEM radio/head unit
There are two common ways of doing this the most simplistic way is buying a Line Output Converter (LOC) this basically creates a rca signal for your amps which is required. The LOC basically you take 2 wires and tap the + and - on both speaker wires going to the rear 6x9's. (There are many great brands out there but I personally use the Scosche SLC-4 since it was recommended to me and works great). You can buy wire splice that crimp on at radio shack for $2-4 bucks. Then you plug you rca from loc to amp input. Check out LOC’s from AudioControl.com especially the 6 port units with summing.
The other way uses the factory installed amp and the PacAudio harness (C2A-CHY) behind the oem deck which provides a set of rca pre outs. Basically you plug in some rcas to the PacAudio harness and run them down the side of the vehicle under the carpet and door sills to the amp.
Installing the Amp (OEM Head Unit or Aftermarket HU)
Your amp requires three wires for it to turn on and function properly. Power wire, ground wire and remote ignition wire. Choosing the wire gauge depends on the amount of amps and the amps draw. For an amp kit they usually tell you how much wattage the wiring kit is designed for sometimes not.
Put a ring terminal on both power and ground wires take the nut off both power and ground at the battery and put the designated wires on the designated screws. Put the negative on a bolt near the positive terminal on the chassis because the less ground you have to use the better. On the power you’re going to want to fuse it to protect your electrical system and amp in case something happens so put an inline fuse 12-18" off the power wire. The fuse however should be the last thing installed after all wire is hooked up and sub is all wire up, to ensure safety to car and equipment.
To determine the fuse size, add up all the fuses on the amps. For instance if you have 3 20amp fuses on the amp, put a 60 amp fuse in the inline fuse holder on the power wire. For the ground wire usually you want to make this wire as short of distance as possible between battery or chassis and amp so interference (alternator wines when you hit accelerator etc.) isn’t brought into the cars speakers through the amp.
Installing the remote wire there is three options tapping into the fuse box for an ignition wire (turns power on when car is on, off when car is off). Or you can tap a wire in a wiring harness found near the battery.
To make sure this wire is the right one, take a car test light put into this wire and the other end of test light to a ground chassis and or battery. If light is off when car is off and on when car is on you found the right wire to use as a remote. The third option is only for those with aftermarket Head units. When installing the aftermarket head unit you will notice in the wiring harness there is going to be a remote wire connect to this wire and run to the amp.
Having some wire loom, zip ties and zip tie bases comes in handy when cleaning up the install and protecting the circuits.
Replacing Speakers
Regardless of what sound group you have you will have 2 - 10 speakers maybe an amp maybe not. These speakers are in the dash, in the front doors and in the rear doors. In regards to the brand and type coaxial or full range component style that is up to you. For this sake I will talk about the most common speakers used which are coaxial. Components can be done but honestly only an experienced person with car audio knowledge should deal with them because of proper imaging the multiple speakers, understanding the crossovers and really the need for their own aftermarket amp. Anyway back to coaxial no matter what size coaxial they tend to share the same characteristic and come in many different configurations. You can get 2 way coaxial which usually mean you have two speakers in one. Usually two ways includes the midbass speaker and a tweeter. Three ways tend to have a midbass and maybe two tweeters mounted above the midbass. Now the main reason to replace these stock speakers is because they tend to have inferior materials. Even the better oem sound groups like the Boston acoustics have paper cones, usually with speakers with better materials (and they range) you will get more performance such as more midbass or more crisp highs etc. Now this is a slight bit of opinion but if you cant afford or plan to replace the speakers in pieces start with the front of the soundstage. Reason being is this is where the emphasis is when you close your eyes your car should be set up where it sounds like there is a concert stage in front of you. In a perfect world you would have perfectly imaged tweeters with sound waves coming directly into your ears. Anyway if you want to tackle the door speakers or dash speakers first that is up to you. But here is something to consider when replacing speakers:
1. if you’re replacing your door speakers you really don’t need anything crazy like 3-way coaxial. A simple 2-way or full range speaker is fine and will save you money. Because the door speakers are usually crossed over at the amp to only receive the lower frequencies you would not be utilizing those tweeters on those 3-way coaxial they are doing probably next to nothing your midbass is doing all of the work so save the money on use it on something else.
2. Same scenario goes for the dash speakers. Using 2, 3 way 3.5" speakers is wasteful per say. With the dash speakers they are crossed over at the amp to only receive high frequencies to keep the sound stage high and in front of you. So really in this scenario you’re only utilizing the tweeter the midwoofers are doing next to nothing. A lot of people even opt to put a 1"-2" tweeter in the dash because really that is all that is needed.
3. Replacing the rear speakers is probably the least important and noticeable of the entire sound stage. You want your music to come at you from the front. Rear speakers are for fill so just match up the specs and go with a 2-way set.
4. Choosing a speaker is completely up to you, people can give recommendations all day long, all speakers will sound slightly different in different cars so many variables go into play in audio systems. Your best bet is hit a few of the local audio shops your best buy, mom and pa audio shop etc. Listen to them and compare what sound you like best.
Sponsored Ad
Register to remove this ad.
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline   Reply With Quote
Old 05-25-2012, 11:02 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
If you want to do your own audio work, good site for beginner car audio information is:
Basic Car Audio Electronics
Steamboat87 likes this.
__________________
MICHAEL
SUPER MODERATOR
Old 08-10-2012, 10:44 AM   #3 (permalink)
Trupiano's Avatar
Registered User
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2010 Ram 2500 6.7L CTD Crew Cab
Engine: 6.7L CTD
Default
Great read guys! Very interesting.
__________________
Trupiano is offline   Reply With Quote
Old 03-28-2013, 05:45 PM   #4 (permalink)
craigsez's Avatar
Ram Year: 2016
Engine: 5.7
Default
When im not so impatient to learn something ill be able to settle down and understand it some but for now when i read it i see fgnkjo;mjkdxl;vnb\hjxckvb\hzujlgvbnjchbvlk/mnvl;k/ c,mnczm,cvb hgx\jkmvcb m, czn..lol gobbledeee gook to me right now..
craigsez is online now   Reply With Quote
Old 06-12-2013, 11:46 PM   #5 (permalink)
Dispatcher91's Avatar
Ram Year: 2012
Engine: 5.7L Hemi
Default
great post but the links to the crutchfield products are not working, Im not able to find the harness to plug in a aftermarket single din head unit. I found a dash adapter but not the wiring harness.. is this something im able to do since the trucks have an amp already?
Dispatcher91 is offline   Reply With Quote
Old 06-18-2013, 09:45 AM   #6 (permalink)
PX8's Avatar
PX8
Ram Year: 2013 Express Crew Cab
Engine: 5.7 HEMI
Default
Do the rears receive full range in the back? I have the 6 speaker basic sound system in my truck.
PX8 is offline   Reply With Quote
Old 06-19-2013, 07:04 PM   #7 (permalink)
Ram Year: 2013
Engine: Hemi 5.7
Default
Would anyone suggest how/where to locate a Uconnect 8.4A for upgrade from a Uconnect 3.0? Is that even possible?
Thanks
detwallace is offline   Reply With Quote
Old 06-19-2013, 07:36 PM   #8 (permalink)
Souths1der's Avatar
Ram Year: 2013 Big Horn QC
Engine: Hemi 5.7
Default
Thanks
I think I remember seeing a post that detailed how the trucks get essetially "programmed" for the corresponding factory stereo that is installed when they're built, and can't be switched to a different version of the factory stereo. That could be only 2013 trucks though.
Souths1der is offline   Reply With Quote
Old 07-19-2013, 12:44 PM   #9 (permalink)
Ram Year: 2012
Engine: hemi 5.7
Thumbs up easy truck to work on
I've installed systems in my old s-10 and my wife's bimmer. These trucks are by far the simplest I've ever installed an amp and upgraded the speakers in. Panels remove and re install easily and don't require many tools.
White Beauty likes this.
lowbean is offline   Reply With Quote
Old 08-27-2013, 10:16 AM   #10 (permalink)
ncaabbref's Avatar
Ram Year: 2013 Ram Longhorn All Options
Engine: Hemi 5.7 w/ 8 sp Auto
Send a message via Yahoo to ncaabbref
Default
On the Longhorn laramie, would the best option would be to just replace the dash and front doors?
ncaabbref is offline   Reply With Quote
Reply
Bookmarks
Tags
audio opinions, audio recomendations, audio upgrade info
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LED Upgrade LB3711 Interior 203 11-13-2016 03:32 PM
Audio upgrade in work 2K10HemiRam Audio & Electronics 78 09-06-2012 02:47 PM
Upgrade to LED's 427invader Exterior 16 08-20-2012 08:50 PM
Final Chrome Modification Stagman Exterior 14 12-04-2011 03:24 AM
audio upgrade jhemi Audio & Electronics 7 07-19-2011 11:44 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
