Auto start troubles
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Hey guys, I'm having some trouble with my auto start. A message pops up on my EVIC saying the hood is open when it's not. I talked to the local dealership and they said I could adjust the hood sensor if the contact isn't that great. I looked at it and there really isn't any way to adjust the tab for the sensor, it's in a awesome place to not have room to adjust it or remove it. Anyone else had this issue with a resolution?
ExpressRules
Southern New Jersey
2014 Express Crew Cab
Have you tried to cleaned the contacts on the sensor and also made sure the connector was tight and didn't have any damage?
KCaudill
The RAM
Blacksburg, Va
Unhook the sensor wire and use a paper clip to short the 2 wires together or if only one wire short it to ground. then they it. that will tell you if its the sensor or not.
