- Dec 1, 2013
- 12,803
- 12,500
- Bristol , Tn.
- 2014 4X4 QC Express 6 speed auto 355 differentials
- 5.7 Hemi
Fantastic information Mike !I'm going to relist some useful links for you from the OEM backup camera thread. If you locate the i550 Tailgate connector back at the end of the truck (and it's intact), and you get the parts that are supposed to be inside the tailgate, you should be able to plug in the needed harnesses to the OEM camera provided you can figure out a way to mount it. Downside is that you may also want to seal up the harness connectors/wires that are normally inside the tailgate against water intrusion (ie w/silicone).
Have a read through the oem mirror kit directions to see how it was installed previously. Not sure if you had dealer installed backup cam/mirror kit or a factory installed backup cam/mirror (different connections where the harness passes through the firewall near the brake pedal).
NOTE: The Schematic for the factory Mirror camera is slightly different, but that shouldn't affect the tailgate end. I will see if I can find/post a link for you and some pictures to this post shortly...
Edit: See post 25 link above for pictures of the i550 tailgate connector. Chances are that the adapter/connector the dealer was talking about (in glovebox) is just a "Sealing plug" for the i550 for when people remove the tailgate.
EDIT 2:
It's possible to get some male terminals and pin an aftermarket camera to plug in at the i550 camera for video and power with that "plug". If the aftermarket camera requires a separate, dedicated "reverse trigger" signal, that wire can be run over to the trailer connector (do not use the one in the tail lights).
Delphi Male Connector Housing Assy: 54241000
Delphi Male 1.5mm Terminals (16-18awg): 54001626 (new pn: 13630404)
Delphi Male 1.5mm Terminals (20-22awg): 54002001 (new pn: 13624759)
Delphi 1.5mm Sealing plugs: 54241629 (new pn: 13755243)
PM me your email and I can send you a schematic for the 2017 "Factory" Backup Camera (too large to link directly)
