Wondering if anyone has definitively solved how to keep the backup camera on at any speed (while using Customtronix Jailbreak or Coastal Electronics Lockpick).
It's not clear to me if you just need to interrupt the "LIN BUS CBC 3" wire going to the camera, either by:
1. cutting-- permanent and therefore no more guidelines when back up, or
2. introducing a switch to that wire-- turn on when needed.
Or, if you need to supply/switch power to some other terminal on the camera's connector/bus.
Thanks!
Thanks!
