Not likely....you would need to crawl under the truck and see how many wires are at the connector that is at the centre tailgate to bed transition area. If you only have 2 wires, then best bet is to get the entire install kit (which has a replacement in tailgate harness with a camera connector). If you have 6/8? then you might already have the required wiring.
