clifford15
- Sep 4, 2015
- 859
- 453
- 2015
- CTD
What is the value of the resistors in post 8? Can't really see the colors (maybe the black and gold). Thanks.
I think they are 100ohm 1/4 watt but I'll double check when I get home later. Have a spare set.
Thanks! I am considering a Pioneer GM-D1004 amp with the Netaudio harness to augment the 5.0 and Kicker speakers. I like the way it is now just looking to get a little more volume. The stock system is pretty loud at 26 though.I think they are 100ohm 1/4 watt but I'll double check when I get home later. Have a spare set.
Anyway, I have read that the radio needs to see a load in order to enable the output amp.
BTW....once I get a couple more posts, I'll have a harness and dq-61 (EQ/LOC), available for the taking!
Right now I have usb cables coming out the back of the radio and thru the big hole in my center drawer. I don't want to keep it this way.
Has anyone used any usb dash mounts on here? Any problems with them, mainly android auto not working? I see them on Amazon with usb/hdmi combo or 2 usb combo. Have high reviews there, just looking for experience from you guys
The usb plug under the center bezel is power only I think on the jump seat models. Wondering if I could just pop that out and install a usb dash mount there
Yeah I wanted to use that when I bought the maestro stuff but read a lot about it not working with android auto. Something about it being intermittent with long cable lengths. My head unit has two usb slots so I guess I could have used this for one of them, but that would still leave me one short for android auto.this lets you keep the console USB with an aftermarket deck
https://www.crutchfield.com/S-G8oc04gF5s2/p_794USBRAM/iDatalink-ACC-USB-RAM-USB-Port-Cable.html
Just 3 more to go bucks130!
Here, I'll help you get another one or two...tell me more about your foxbox setup. What size sub and what's the rating on it? And same with the amp that's powering it.
There doesn't seem to be anything beneficial to getting a new amp or even sub I'm noticing, right? The newer models might be a little smaller. But if your old stuff is working, and it fits in the space you want it, its best to just reuse it.
how long ago did you order from them, i have a foxbox in one of my trucks and would like another for my other trucks but i wasnt sure if they were still around
I don't remember the exact time, but it was with the last 6 months or so. Which box do you have, single or dual, sealed or ported?
i have one of his older (better IMO) model boxes, its a dual 12" sealed, it will slam very well, two kicker cvx 12s it flexes the doors on the truck and has broken my overhead console and actually shattered my LED bulbs inside the dome lights and i just molded a double din in the dash.
this is all in my 03 btw
Wow that's pretty impressive! Did you have more room in the 03? Of course with a dual box, you prolly get more room overall than a single
