Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Audio & Electronics
Audio & Electronics
Building my own fiberglass sub box - to vent or not to vent?
This is a discussion on Building my own fiberglass sub box - to vent or not to vent? within the Audio & Electronics forums, part of the 4th Gen : 2009 - Present category!
I've got a 12" MTX sub from years ago that I'd like to take out of a ported box and ...
Like Tree3Likes
Reply
Old 08-19-2016, 04:30 PM   #1 (permalink)
AKR
Ram Year: 2010
Engine: 4.7
Default Building my own fiberglass sub box - to vent or not to vent?
I've got a 12" MTX sub from years ago that I'd like to take out of a ported box and stick under my back seat. I listen to mostly pop/dance/indie electronic and I don't want really tight bass. I've seen a number of threads here and elsewhere about people building their own fiberglass sub boxes, but I can't seem to find any that are ported/vented. Is anyone doing this, and if so, do you have pictures/instructions?
The MTX sub enclosure guide says to not vent it into a wall or anything, and if you do, you need to build the port smaller. So, I'm thinking I either need to go small and vent it towards the back wall of the truck, or go large and vent it between the front gap under the seat by making a short wall of MDX that the top MDX panel sits on. I guess either way, I'd need that short wall of MDX for the vent.
Sponsored Ad
Register to remove this ad.
AKR is offline   Reply With Quote
Old 08-19-2016, 05:48 PM   #2 (permalink)
Etroze86's Avatar
Ram Year: 2011
Engine: 5.7 Hemi
Default
Always vent if you have the airspace. Now a proper enclosure for any sub will dictate how it sounds. I have an 18" sub that kicks tight bass like an 8" but it will boogie and play some deep edm stuff when asked.
Personally if I was dealing with the underseat storage solution it would be really fun to port a couple of Sundown SA8's and blow away that MTX you have.(unless its like a 9500 or jackhammer).
__________________
2011 Express 1500 Debadged, Access Cover, Diablo Intune, S&B Intake, 2/3 GF Drop, and More Watts Than I Care to Explain!!!
Quote DavidRam- "They'd look cool sitting on my TV stand... Bang & Olufson designers can kiss my ass!"
Etroze86 is offline   Reply With Quote
Old 08-19-2016, 07:16 PM   #3 (permalink)
Ram Year: 2015
Engine: Hemi 5.7L
Default
I'm assuming you've never built a vented box before. The reason why most go sealed is that its a more simple build given the obstacles us ram owners have to work around under the rear bench seat.
Now I'm pretty sure you can buy a prefab 12" foxbox vented enclosure for under the seat. BUT before you go out and buy something like that, id suggest doing some reading on the sub and the box to make sure they will compliment each other. You might want to do some reading vented enclosures in general also.
What series is that MTX? You say its old are we talking like a Thunder 6000 or 8000, or the newer 6500 series etc.
Ideally you want that data sheet. If you don't have it Crutchfield should have a lot of that info on their site even if the sub has been discontinued you'll still be able to find it.
Try to post some more specific info if you can. There's a lot of knowledge on this forum but nobody can really help you without knowing exactly what you are working with.
John94z is offline   Reply With Quote
Old 08-20-2016, 01:04 AM   #4 (permalink)
AKR
Ram Year: 2010
Engine: 4.7
Default
This thing is close to 20 years old. It just says "Thunderpro 500 watts total power" on it. My amp is an MTX Thunder 280. Looking at the specs, it sorta looks under-powered, but I remember it sounding good when it was working. I'm not sure if I should go ahead and break the seal on the sub in the box and see if there's more info on the magnet.
I'm sorta wondering if I should just ditch both of these and get some moderate upgrades since my birthday is coming up next month.
Old 08-20-2016, 01:33 AM   #5 (permalink)
Ram Year: 2015
Engine: Hemi 5.7L
Default
Good god man lol i thought i was an old school fan talking about stuff from about 10 years ago. You are running gear from when i was in elementary school. Very cool stuff however i would recommend buying some new stuff. I actually had to look up your sub and it looks like it may even be older than the Blue Thunder series. A couple things: Your amp was never designed to run a sub like this. Secondly, your sub certainly has some years on her. One of the most concerning things to me would be the foam surround on it. 20 years is really pushing it. I would not be surprised if the foam itself started to degrade and even the adhesive securing it to the woofer cone and basket. I would recommend some new equipment. A lot has changed over the years and you wouldn't need to spend a whole lot on something that will run with that setup of yours. Food for thought.
You may be able to get some decent money for this equipment on ebay from the right buyer also. This stuff is old enough to be back when MTX was american built. Some people are enthusiasts for the old school stuff.
AKR likes this.
Old 08-20-2016, 09:36 AM   #6 (permalink)
AKR
Ram Year: 2010
Engine: 4.7
Default
Oh god, I'm old. lol. Yeah, this was my set up just out of high school. Alright, thanks for the advice. I think I'll start planning for a new set up rather than mess around with something that may need to be replaced shortly anyways. I'll decide on a new sub or two and then start designing the fiberglass box around that.
Old 08-20-2016, 11:54 AM   #7 (permalink)
Ram Year: 2015
Engine: Hemi 5.7L
Default
No prob. Normally I'd say to go ahead and run it til it gave up on you but if you are going through the trouble of building a custom box then you should build the box around the sub you plan to run so you get the most out of it!
Old 08-21-2016, 10:33 PM   #8 (permalink)
Ram Year: 2016
Engine: 3.6L
Default
ported enclosures typically need more airspace than sealed enclosures. There is not a lot of room under the rear seat for a 12" sub and a ported enclosure, there is just not. Now if you had a mega cab, I would say go for it and build the box behind the rear seat.
John94z likes this.
__________________
Thanks,
Stephen
Audio Upgrades: NVX XPLOC4, (front) RF Punch P165-SI, (rear) RF Punch P1650, (Sub) OEM box, NVX JAD900.5
BadHabit2Break is offline   Reply With Quote
Old 08-21-2016, 11:51 PM   #9 (permalink)
Brody57's Avatar
Ram Year: 2014 RCSB
Engine: Hemi 5.7
Default
As the others have stated, ported is by far the way to go. But with your room restrictions a sealed box would give you way better sound output. Make sure and post pictures when you're finished!
__________________
Brody57 is offline   Reply With Quote
Old 08-22-2016, 08:18 AM   #10 (permalink)
Ram Year: 2015 Laramie
Engine: Hemi 5.7
Default
i wish i could find pics, back in the day i saw someone build a slot port box in one of these truck and they had the port go up the back wall of the truck so they could get the max airspace needed.
baum is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
