jlchristopher
Has anyone found an adapter that will allow the to swap an aftermarket 7" headunit for their 8.4"?
I just had a whole new system installed in my 13 Ram and i'm getting a horrible hiss from all speakers after the aftermarket amp. Not a grounding issue.
Equipment listed below.
HD 900/5
4 C2 6x9 coaxials (Yes the fit) - May be going to 6.5" components. Highs are bright.
1 10W3v3 with attrend BBox
JL Audio amp wire kit.
The shop is a JL signature shop and they did speaker level inputs directly into the amp using JL speaker to RCA adapters from all 4 channels pulled at the pillars. Shop confirmed that front and rear speakers are full range from the headunit.
The problem is that these headunits have a high noise floor and the hiss is audible with audio at 0-6.
It is not from running power and speaker wires too close together. Not a bad ground, and it is not the amp itself. When I unplug the high level rca's the hiss leaves which tells me that it is from the headunit signal itself.
I can't find much info about swapping the headunit for aftermarket, and Crutchfield doesn't recommend it at all.
I have ordered the FiX-82 from JL which is the updated cleansweep that will be delivered tomorrow, but I don't want to give up the headunit volume control or rear wheel volume control for a knob.
What say you Ramforum members?
Do I live with it? Install the FiX-82, or search out ways to get climate controls into aftermarket headunits for the 8.4"
I have posted this on another Ram forum to get more info.
HD 900/5
