that white kid
- Nov 14, 2012
- 517
- 31
- 2012
- 5.7 hemi
Has anyone on here got rid of the middle front seat and put a sub built into the center console
I already have 2 10in L7 under my seat but i like alot of boomI'm sure with some work you could get an L7 in there.
I have a 10" L7 and that ******* is HUGE!
That being said, I'm sure you could have it fire backwards (towards the cab wall) or similar w/o an extensive amount of effort.
So you want to run two 10's under the seat (which you have) then run another sub in the center console of a different size?
You won't be happy with that...cancelation issues, research it
Wont be much of a cancellation, that woudl be more where one sub takes away energy of another. Having say 10's under seat, and an 8" up front in a center console for midbass would be fine IMHO.
IF he was running an 8" for midbass up front, he'd be fine because he would have different crossover points....but that's not what Iam getting from his post. The problem will occur when he's crossing these different sized subs with the same crossover points. Also, not knowing his slope at what decibles will cause a problem with giving him advice. Ultimately he's looking for his subbass to play better at lower frequencies which is always a problem with these under the seat enclosures.
OP, you'd be better off building a center console enclosure for whatever sub(s) you want and tune the enclosure to 30-32hrtz. Forget about running two diff enclosures....you won't be happy. This has been covered many many times in car audio....it's simply not an intelligent way to get lower frequencies to play louder, richer, smoother whatever the case may be.
I would rip those 10's out from under the seat,
build a sweet enclosure tuned properly for the center console, and be done with it....you'll never go back to an under the rear seat pre-made enclosure again....I can promise you that!
Well if two tens are under the rear seat, and assuming the center console is up front, which they are, a midbass 8" is exactly what I was referring too as a midbass. If the 8" is in a sealed enclosure, it wont have a peaky frequency around the port tuning. Why not run the midbass form 50hz and up to say 350?
The problem isnt really different size woofers, it's lack of airpsace to properly get maximum low bass extention under the seat. Why most audio manfactures make a slim mount sub, to help gain back some lost depth and or space limitations.
The problem with the OP's setup is just lack of airspace for the sub he's using. While we say they will work in a .66 sealed, they really shine in larger ( 1.75 per) or small ported, 1.25 to 2.75 and you'll see huge gains. But stuffing them under a small seat, you wont get the low bass he's looking for.
For the driver, sure maybe putting a sub (sealed or ported) in the center console will work, it will sound terrible to the passengers in the rear as the bass will be in front of them, and loose all the staging.
Op can do whatever, just offering advise from our products mentioned.
I am agreeing with you when it comes to an 8 being a midbass up front, but the OP is not looking for a midbass ran up to 350hrtz. He's wanting his subbass to perform better from 50hrtz and below. And you are correct, the problem is lack of airspace. That is why I told him to ditch the enclosure he has and build a center console enclosure where he can tune the box to perform better with lower frequencies which in turn will improve output and overall sq. How will a center console enclosure sound terrible to the people in the rear seat area? Do you actually think the bass in a sound stage should be behind you?? What kind of concerts have you been to where the drummer is at the back of the area? Or a bass player? A sound quality goal is to get as much bass up in front of you as possible....it's a sound stage!!!! And why are we focusing on what the people in the back will experience? Hell, my truck is time aligned to where everything is focused on the driver's seat...I could care less what the passengers think, let along my passenger sitting next to me! Are you in the industry? Are you trying to help the OP or sell stuff?
A fellow SQ competitor has one 12" JBL MKII in a vented center console enclosure. His truck sounds beautiful with a lot of fun factor. Just for giggles (as he is solely an sq guy) we metered his truck and he hit 155 db's from 750 watts. That's pretty damn loud and can be obtained from the OP if he chooses.
