Cluster Problem
Twotwenty
2014 Dodge Ram
3.6L
Help
My cluster doesn't work. When I start the truck I just get a red dot and then nothing else. Everything else in the truck works just fine
cgeorgemo
Joplin, MO
3.6 Pentastar
Help
I've had mine take a few seconds to start working twice now. I believe it just didn't boot up correctly when the truck powered up.
Cycling the ignition fixed the problem both times.
Course my cluster is from a different truck. Is yours the one that came with your truck?
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
This should be in the audio and electronics section. Would get more help.
I have never had that issue. But these are all computers so they need a good restart every once in a while.
Pull the battery cables for about 20 min. Should reset all the computers.
T
Twotwenty
2014 Dodge Ram
3.6L
Sorry I left that out but I was trying to do the upgrade. Even when I switched back to the original one I still have the red dot and nothing else. I disconnected the battery overnight and that still didn't fix it
T
Twotwenty
2014 Dodge Ram
3.6L
Check f49 and f88 and go from there f49 is a red10 fuse and f88 is a blue 15 fuse
I checked both and and pressed them in but it didn't work
Edit: I just checked and I'm getting a reading from the f49 but not from the f88.
