the system comfort setting will not turn off in my truck no matter what its always on. has anyone had this issue or fixed this no matter what setting i turn off and on it always pops back on all the fuses are fine no bad relays or grounds. the reason i want it off is because when i auto start my truck the heated seat does not turn on. i have to turn the truck off open the door and restart my truck for it to turn back on and then its fine. anyone know what going on here ? im out of ideas and cannot find a single thing on this.
Hi doug2013,
I did some research into the function you are referring to, and located the following information in the Owner’s Manual:
“The Remote Start Comfort System can be activated and deactivated through the Electronic Vehicle Information Center (EVIC).” Pg 28
“Remote Start Comfort Sys. When this feature is selected and the remote start is activated, the heated steering wheel and driver heated seat features will automatically turn on in cold weather. In warm weather, the driver vented seat feature will automatically turn on when the remote start is activated. These features will stay on through the duration of remote start or until the key is turned to RUN. To make your selection, press and release the SELECT button until a check-mark appears next to the feature showing the system has been activated or the check-mark is removed, showing the system has been deactivated.” Pg 260
If this information is not applicable, please feel free to reach out and I am happy to assist you in scheduling an appointment at a certified dealership for service.
Anna
RamCares Social Media Specialist
