BradKnob
- Mar 12, 2014
- 1,382
- 395
- Prairieville, LA
- 2012
- 5.7 hemi
I show two different part numbers for the mirror flag. Not sure why unless it's a trim specific due to color? Maybe the longhorn version are brown or something?
Left side
1HA43XDVAA
1HA43DK2AA
I'd send them straight to brad and have him make you on axis setup.
You might try to get them glassed a little more on axis. Although many tweeters are designed and work better off axis. I just can't wrap my head around using the sail panels. Tweeters firing down and the reflection off the steering column has to be affecting the response. I would think mounting like Brad would work better if you plan to keep them there. My advice. Get some two sided tape or industrial Velcro and temporarily mount them to ensure you like them there.
Once u get them in the sails, with the door shut, u can take them off and aim them in different directions. Lay the sails with tweeters facing right at you then put em back on regular, then u will see if it makes any difference to you which way they face.
