I have a 2010 Ram, 1500. The drivers side door lock/unlock switches do not work. However the passenger side switches work fine as do the fobs. Also, the locks will intermittently lock with no button activation. The window and mirror switches work fine.
The switches have gotten wet a few times in the past.
Is there way to check the door switches? Is it possible that this is a switch issue, or a control module failure?
Lastly, I don't know if this matters, but I also have an unresolved TPMS sensor issue (possible bad sensor, but no codes).
Any ideas?
Drew
Any ideas?
Drew
