Honeybadger556
Has anyone else seen this? It's not dirty at all. Can I take it apart?
If you are talking about the link that I provided, the answer is NO. That camera from Amazon has an RCA plug, whereas the OEM camera is regular wire connections.So if you replace the OEM camera with a after market camera is it just plug and play ? Any issue with the connection? Thanks
Here's one just now with a Google search of the camera p/n 56038978__If you are talking about the link that I provided, the answer is NO. That camera from Amazon has an RCA plug, whereas the OEM camera is regular wire connections.
I'm sure you can buy the OEM camera, but I have yet to see them for under $150ish
