mhb1638
- Oct 1, 2013
- 766
- 248
- Savannah, Georgia
- 2019
- Hemi 5.7
Here is what I would do if you want a decent setup. See if you can return the kicker sub. Return the 4 channel amp and buy a decent 5 channel amp. You will have less work if you do it this way. If you can't return the sub disconnect the amp from the sub. but use the sub with the new amp and the kicker speakers. You will be able to run all of your speakers and sub through one amp and then add the bass knob to control the bass output.
5 channel isn't a bad idea.
