Headunit wiring help
bloombloom88
Plano, Texas
In the picture shown i have the yellow power wire from the headunit harness connected to power, the unit gets power and the red light flashes but doesn't turn on.
The red wire shown is the ignition wire on the headunit harness, if that wire is connected with the yellow power, the unit will completely turn on, if its not the red light will only flash.
What am I suppose to do with the ignition wire? I assumed I run it to the fuse box under a ignition fuse but the headunit will not completely turn on that way.
Can somebody help me?
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons make you fat...
TheMaddog
DFW
is the harness and the hu from the same company?
bloombloom88
bloombloom88
Plano, Texas
Yes it is the harness that came with the kenwood
4x4Hemi
Edmonton, Alberta
I'm not sure if this works haha but could you wire it to the cig lighter?? I don't know much about this stuff haha would that work or ??
TheMaddog
DFW
Everything should be color coordinated if its the same brand.
BLKDODGE04
Wataga, Illinois
4.7 Magnum
would that be the same for an 04? if so i can go look at mine to see what color wire the red and yellow are hooked to... ive installed all my own radio's in my trucks and my wifes cars.
bloombloom88
bloombloom88
Plano, Texas
I ended up running it to the fuse box under the fuse for the power windows. Thanks for the quick responses!
MikeP
Brooksville FL
Maybe I'm misreading it but wouldnt it be better to run it to the radio fuse instead of the power windows?
Sent from my SIII using Tapatalk 2
