DoubleTap
So I am 99% done with my aftermarket subwoofer install into my 2014 Ram 1500 CC with base 6 speaker system and 8.4an navigation head unit.
Do you tap into the rear door speaker wires or front door speaker wires for signal when installing an aftermarket sub in 2014 Dodge Ram crew cab with base 6 speaker system with 8.4an navigation factory head unit? I have 12" ported fox box, 12" sundown SA 12" sub, 650w PPI amp mono 1 channel D class. I ran 0 gauge OFC Knukonceptz from the battery to the rear cargo area. I ran the 0 gauge to a power distribution block with a single 0 gauge input and two 4 gauge outputs. For now I am running 4 gauge OFC cable to just the one mono amp for the sub as I am not sure if I'm going to amp the aftermarket door speakers I'm going to install this week and I plan on powering the aftermarket dash speakers from the factory head unit. But I will at least have the option to run the rest of the OFC 4 gauge to the 4 channel amp I have if I decide to amp the door speakers. That way I don't have to redo the entire system all over again if I decide to amp the doors. And I am running an audio control LC6i.
I have everything done and installed other than tapping the door wires for signal since I don't know if it is the front door speaker wires I am supposed to tap into or the rear door speaker wires I am supposed to tap into. So that is the million dollar question....do I tap into the front door speaker wire or rear speaker door wires for signal? And what color are the door speaker wires I tap into?
Thanks in advance
Thanks in advance
