help on radio upgrade
BigDaddyRam
San Antonio, Tx
This is in my 2014 Express. What options do I have for upgrading? Can I go all the way up to the 8.4 with nav? What else will have to be swapped out? Is it plug and play?
[/IMG]
Ricks Ram
Yes you can go all way to an RA4. There several posts on it in the 4th gen DYI section. It is all plug and play. The only thing you need is a custom harness for the RA3 or RA4 you can buy it from Cuyler Tech he is a supporting vendor here and a member on the forum. Read the posts and get the info. It is easy to do. I had the RA2 this is mine after the upgrade.you will need the heater control module,the 8.4 bezel,the RA4 radio and the harness and the 911 adapter . You can also add the bluetooth by buying the correct mirror and the mirror harness and steerig wheel controls it will all work. It's all in the 4th gen DYI section.
1500ram12
5.9L Cummins
I installed a 8" alpine unit
Sent from my VS985 4G using Tapatalk
Jared4.7
Olathe, KS
2017 Bighorn CC
Go factory!!!
-JT
