bloombloom88
I was driving to work this morning and all of a sudden both of my headlights just turned off. Thinking it's my headlight switch, I moved it from auto to on, no change.
The lights came back on, and turned off a few more times. I hooked up my cortex tuner and got 3 of the same codes I've had in the past when having issues with my lights.
Left high beam circuit open
Left low beam circuit open
Lost communication with radio
The last time I had issues, I moved all of the grounds directly to the neg post on the battery and the problems went away. That was about a year ago.
NOW.. Last night I did use my high beams a few times, maybe this has something to do with it? I normally don't use them, and haven't until last night since moving the grounds.
I need some help, I can't be driving around with unpredictable lights.
