Needing a wire guru for this one. I converted a 2015 ram 1500 ecodiesel SLT to a have a sport front end and so now i have the projector headlights. I used the retrofit harness to adapt them to my quad headlight wiring which works great. Then i installed HIDs in my fogs and lows (last year...when there was no HID kit for 15s) which required me to track down a wire behind the dash to use as the signal wire since i was having no luck using the low beam wire as a signal with it being what i would call a "digital" wire (does not send a constant current so the relay would buzz on/off). So anyways i managed to get the HIDs working by running the signal wire for the relay behind the dash and cutting the lowbeam wire in the retrofit harness (no error codes or light out codes at all surprisingly). But now my issue i am having is that my truck being Canadian it has DRLs, and since it is an SLT it sends a low voltage signal through the highbeam wire and not to the amber LEDs like a normal Canadian model sport would have. So now I have ordered the DRL-1 module so that i can use the amber LED turn signals as my DRLs instead. But then i will want my highbeam DRL (factory DRL) disabled. I just brought my truck in to a dealer to have it disabled as they told me it was possible...now they are telling me it is NOT possible after looking at my truck for an hour. So i have been on the phone with dealership after dealership and even called Ram direct and they told me to bring it to a dealership....
SO now i am at the point where i am done trying to disable the highbeam DRL and am simply going to cut the highbeam wire on each retrofit harness and instead i will run a relay harness to my highbeams but in order to do so i need to find an analog wire that only comes live when the highbeam is turned on. SO long story short, i need a wiring guru that knows which wire i can splice in to to use as a signal wire for a relay to control my highbeams with normal functionality like i did with my low beams.
And secondly, if someone is able to figure that out... maybe they would also know of an analog signal wire that only comes live when the fog lights are on?
OR maybe someone knows how to actually disable DRLs on 2015 Canadian Ram trucks!? This would be the easiest but it is seeming like it is simply not possible.
