sbarron
- Feb 28, 2015
- 3,362
- 2,277
- Wasilla, Alaska
- 2013
- 5.7 HEMI
The market will eventually dictate which products are successful and which aren't. Nobody is not buying a Ford or Dodge because of Sync or uConnect. Other, more important features loom larger. Nowhere did it say, and I guarantee if you look at the legalese, that your particular phone will work with these features.
You said it yourself, "if you knew..." Your problem, you didn't research and assumed it was a perfect system. If the service doesn't work, cancel it and ask for a refund. THAT is perfectly within your rights and if approached reasonably, even likely.
Use the money you saved on the subscription to buy a cell enabled remote start and your phone for the GPS.
