2500Ram2012
- Dec 19, 2014
- 8
- 2
- 2012
- 6.7
I took bits and pieces of information that I found on this and other forums and I want to give back.
I wanted to add a 2013 '3rd brake light' camera (CHMSL) to my 2012 Ram that only has a tailgate backup camera. It was also a requirement of mine that the camera image be displayed on my stock NAV radio. After I completed, I can switch between my tailgate backup camera as well as the cargo camera while driving using my steering wheel controls. The CHMSL camera really helps with blind spots and merging.
I have:
2012 Ram 2500 4X4 Crew Cab Laramie 6.7l w/ Auto Transmission
Stock tailgate backup camera
UCONNECT 730N (RHR)
What I ordered:
Mopar - Wiring-Tailgate: 68189124AB $30.70
Mopar - Lamp-Cargo: 68163937AE $185.50
Coastal Electronic Technologies: MYGIG Lockpick V.5 $289.00
Amazon - PTC 25ft 3-RCA Composite A/V (Red/Yellow/White) Cable $10.39
Local source - RCA female connector
20' of black and red automotive wiring
What I did:
Modified the Wiring-Tailgate harness that I listed above
Unwrap factory electrical tape. Note: leave the factory heat shrink in tact
Cut wiring harness a #1
Throw away connector #2
Throw away connector #3
Save connector #4
Now I started building the wiring harness I would install on my truck. This custom wiring harness will connect to the new CHMSL camera (3rd brake light camera). This harness will supply power, ground and 'signal return' to the camera and supply camera signal to the LockPic hardware.
To build this harness I started with a spare female RCA connector I had laying around.
I stripped the wire end (#5) .
Next, I started working on the camera pig tail (#7). The Blue and Yellow wires are unused. #8 is the connector that will connect to the camera
Solder #5 center wire to #7 Green wire
Solder #5 outer wire to #7 Clear/White wire
Solder #7 Red wire to your red automotive wire
Solder #7 Black wire to your black automotive wire
If you're interested, these are what the camera pigtail wires are for:
Black = Ground
Green = Camera Signal
Clear(white) = Camera Return
Red = Switched 12v
Unused:
Blue = CAN bus
Yellow = Camera Shield
Separate the yellow RCA cable from the audio cables. Connect the Yellow RCA cable to the custom harness (#6)
This is what my custom harness looked like. I added foam ever few inches so the harness wouldn't rattle in my headliner
Remove center dash and console.
Install LockPic per their instructions
Remove stock 3rd brake light. Install custom wiring harness through the headliner down the 'D' pillar trim under the carpet and up into the center console area.
Connect the camera connector to the CHMSL camera (#9)
Connect the vehicle's stock CHMSL connector to CHMSL (#10)
Tighten CHMSL to vehicle
Connect custom wiring harness Red lead to LockPic pigtail "accessory switched 12v
Connect custom wiring harness Black lead to LockPic pigtail "ground"
Connect Yellow RCA lead to LockPic 'Aftermarket Baby or Right Camera Video' input.
Button everything up and enjoy.
I have:
UCONNECT 730N (RHR)
What I ordered:
What I did:
Save connector #4
Black = Ground
Red = Switched 12v
Unused:
Blue = CAN bus
