Do you have pink from ASWC to Pin 13 and Blue/Pink to pin 2? Pin locations should be numbered on the factory harness. No other wires should be hooked up besides power/ground (red/black). If you do, double and triple check all connections are secure and tight and that you have the right pin numbers.
Once you confirm that, use a pick tool to hold on and reset the module, it will flash rapidly, during this time press and release the volume up button continuously until it stops flashing. It should then flash green 7 times with the 7th flash being a longer steady green. Then it should flash red 6 times. From there it should not be flashing any longer, only when a button is pressed.
