Very nice to hear indeed !Good news. I think I solved the problem. It turns out that it is the tailgate camera harness has a short in the cable! If I bend the cable at a certain angle I have full picture and lines.
The harness Going to the tailgate from the main truck harness has 8 wires ?
And 8 wires going to the front of the truck ?Yeah, there's 8 wires going into the tailgate.
Okay , you have a 2015 .
With that said , mine is a 2014 .
To me knowledge, there's no diff between 14 &15 .
So if you have 8 wires heading fwd of the tailgate harness , then answer me this sir ,
1) what Radio do you have ?
2) did you have a back up cam already ? Display in the rearview mirror ?
If the connector that looks like this .I just did a quick check at the tailgate connection for wires going into the tailgate and saw 8, didn't open up anymore than that or check anywhere else on the truck. Where else would I check for the 8 wires, at the same connection or at the front of the truck somewhere?
Hey i went about it a little differant, let me know what you think.Good work on the pictures.
Especially the PDC power wire and explanation. I think the directions intend for that power wire to be cut through, both ends stripped, slide the heat shrink over one end and the new wire, then twist, crimp and solder all 3 back together and heat shrink the new joint. Personally, I hate breaking a perfectly good conductor If I can help it and your solution with the liquid tape is a solid alternative.
I can't say for sure since my install with Jeepguy's Custom harnesses was slightly different but from reading the Official Kit's directions I 'believe' that you shouldn't have had to cut any wires at the back near the tailgate like that to change pins from male to female unless it is to extend those wires because of the modified bumper you have. If you are at the correct "body side tailgate connector", you should have had female pins.
Instead, the new chassis/Camera harness gets the original 2 female lock solenoid pins added to it at pins 7 & 8 (i550) which in turn plugs into that 6 inch tailgate extension, which goes to the bottom connector of the tailgate/harness.
Honestly, I never realized the extension was there at all since it and the main tailgate harness were already in my truck's tailgate (likely because of the existing power tailgate lock). If I may ask, what is your Trim Level and vin to hunt for your Tech Authority schematics? (maybe its a 2014 thing or the factory messed up the harness and the extension was their fix).
The i550 connector should be one end of that extension and should have been originally secured at one end near the spare tire. I would imagine the purpose of the extension is to serve as a wear and tear item, taking the abuse of the tailgate opening and closing so that it is cheaper to replace that extension than the tailgate or chassis harness on either side.
It sounds like you will be able to get it all worked out, but I went ahead and pulled these pictures from Jeepguy's DIY Camera (Custom Harness) thread OP to show the location of i550 connector I am talking about with the 2 female lock solenoid pins from the existing chassis harness that must be moved to the new camera chassis harness' connector.
Hopefully it will help clarify the directions further.
I might be wrong, but that's my understanding since cptwing didn't mention having to do that with the same kit. I may have to go take a look under my truck again if I get up before the snow gets here today and double check. Hmm.
8/1/15 Edit: Added i550 tailgate extension note/picture.
Sent from my "Up All Night Sleep All Day" Nexus 5!
I am new to the forums but i own a 2015 ram 2500 bighorn.
I simply left the jumper harness plugged into the harness with just the two wires, and removed the female wires out of the other end of the jumper or "harness extension" and hooked them into the kit harness A, which i then plugged into the D harness that goes into the tailgate and upbto the handle.
Just let me know what you think please? Thanks
Did you get your camera harness fixed ?Good news. I think I solved the problem. It turns out that it is the tailgate camera harness has a short in the cable! If I bend the cable at a certain angle I have full picture and lines.
You can probably remove the tape from that litle short camera harness , find the problem and fix it yourself ...
Did you get it done sir ?Not yet, sent the harness back to vendor, getting a replacement. Will update when I get the new harness.
Still can not believe I did not have to get the flash.
I don't recall exactly but there is a TPA (terminal position assurance) lock on the front of the pins that may need to be removed before the pins will come out.I am having trouble getting the 2 pins 7 and 8 out of the i550 to move to the new one. Can somebody give me some pointers on how to do this?
If you take a pick or 90° scribe and remove the rubber weather seal from the front side it gives you better acess to the connectors pins .I am having trouble getting the 2 pins 7 and 8 out of the i550 to move to the new one. Can somebody give me some pointers on how to do this?
