2016 Ram Laramie. My interior dimming dial switch will not work. It will not turn lights off,make them dimmer, nor will it make them brighter (when moved to the right), nor will it turn on dome light if rotated all the way to the right. If I use the Uconnect 8.4Nav controls, I can go to manual and adjusted them through the touch screen. Just the dimmer dial switch seems turned off. It doesn't matter if heads lights are on, or if they are off.
Any thoughts?
Any thoughts?
