j1877p
Well, I'm going to apologize in advance because this build will take me much more time than I would like, and as such there will not be regular updates quite as often as some would prefer. I am not a patient man and this install will definitely be testing my patience. This thread will act, not only as timeline but, as research for the build.
I have been into home and mobile audio since the 90's and have had a system in every vehicle since my first car ('86 Chevette........stop laughing). I have never ran an active system but will be with this build. I am by no means an expert, far from it, and welcome suggestions and opinions.
So I am in the research phase of my build and I can give you some details or guidelines.
1. I will be keeping the 8.4a, with added navigation intact
2. I will be re-using some equipment from previous systems
3. I will be at least for now keeping a mostly stock appearance
4. This will not be a straight sound quality nor straight SPL build
5. I listen to all kinds of music from Hip-hop, Rock, Pop, Electronic, occasionally country and everything in between
To answer the questions from #2 above, lets list the equipment I already own that could potentially find their way into this build.
1. JL Audio HD900/5 amp x1
2. JL Audio XD500/3v2 amp x1
3. JL Audio 12w3v3-2 sub x1
4. Polk Audio db6501 components x1
Everything is subject to change and this is just a starting point due to me already owning this equipment. I am already thinking of changing the components.....we'll see.
If I keep everything, this is what I am thinking....
From the 900/5
2 channels to the db6501 mids in the front doors
2 channels to mids in the dash (TBD)
sub channel to the 12w3 in a sealed enclosure
From the 500/3
2 channels to the db6501 tweets in the door sails
sub channel to 6 1/2", 6"x9" or 8" subs in the rear 6"x9" openings (TBD)
I will start the build by upgrading some of the electrical system (Big 4). Sound deadening will be next. Then I can begin wiring and installing equipment.
Any thoughts or suggestions? Keep everything, get rid of something, change everything?
From the 900/5
From the 500/3
