jkhcurry
- Dec 19, 2016
- 11
- 1
- Corpus Christi, TX
- 2016
- Hemi 5.7
Can someone help me understand how to wire in 2 LED light pods to my reverse lights, and tap into the factory LED bed light harness so I can use that switch to turn on lights if I wanted without truck being in reverse.
I have a 5 pin relay with attached harness MAH-112-C-1 with the following diagram:
30=Black Positive
85=Red Ground
86=Yellow To Switch
87=Blue To Light/Accessory
87A=White
This is how I thought it would go:
30=Black 12V power from 7 pin trailer adapter.
85=Red Ground to frame. (Or should I use 7 pin trailer ground?)
86=Yellow Connects to positive wire for LED bed light harness
87=Blue Connects to both LED pods positive.
87A=White Connects to reverse light on 7 pin trailer adapter.
Connect both lights ground on frame.
30=Black Positive
85=Red Ground
86=Yellow To Switch
87A=White
