dogcar3
- May 16, 2012
- 406
- 132
- 2012 Power Wagon
- Hemi 5.7
EDIT: solution in post #5. solved.
So I ordered up a Lockpick v5. I followed the instructions. But my radio does not turn on when I turn the truck on.
Switches 1 and 2 are down for the 'fast' bus. Vehicle select is at '0'. All other switches are up. I have double and triple checked for bent pins. I hooked it up with no key in the ignition and already configured.
When I hook it up, the light ring around the power button lights up for a fraction of a second (screen never shows anything), waits several seconds then lights up again (again, nothing on the screen). But this time for roughly 15 seconds. Then nothing. No matter what I do.
I called the Lockpick technical support yesterday, but I was (and am now) at work so I could not really get too into it with them. They just gave me the same run down the instructions say.
So I need some help from anybody who has installed the v5 into a 4th gen. I know there are several who have a v4, but there seem to be significant changes between the two versions.
Any ideas?
If I can't get it working, I will try to find time to call technical support and not be at work during their hours.
Any ideas?
