Overhead console install and bt mic 2017
crazykid1994
Florida
Well adding the overhead console to my 2017. The mics run through the driver A pillar. Harness info
That's above the liner. Told a few people I'd get pics and info.
Output of harness behind driver AC vent feeding up.
In on harness
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
so the mic harness isnt on the pass side anymore
crazykid1994
crazykid1994
Florida
Mic part #
Location of mics. Yes 2 mics
Demon-HeMi
Houston
oh ok yours are not in the mirrors
crazykid1994
crazykid1994
Florida
Colors feeding is gray striped with green and green striped with gray
crazykid1994
crazykid1994
Florida
Ok so on the harness by the AC vent red #1 seems to be constant 12v and yellow with the purple stripe in 11 is the switched for the dome light.
crazykid1994
crazykid1994
Florida
Just so everyone knows the pinout kit will be different for 2017. I had to modify the pinout kit that came with my overhead console to fit the factory harness in the dash.
crazykid1994
crazykid1994
Florida
Anyone know if there is a blank to fill in the rear window switch?
crazykid1994
crazykid1994
Florida
If anyone has a 2017 with the overhead console and bt can they check for the harness info is I can attempt to get the proper harness
1Popeye
