603photog
- Jul 10, 2016
- 79
- 60
- New Hampsha', ayuh!
- 2012
- 5.7L HEMI
Thanks to the advice from the members who replied to my previous thread along with the help I got from my good friend Google, I was able to install my new Pioneer AVH-x5800bhs all by myself. What a project!
I'm not going to write this post as any sort of a tutorial because, honestly, there's enough of them out there. I'll just show the before and after pics and provide a couple points of commentary.
To start with, I had the 130 (not the 430 I previously thought I had) :
Following the directions I found in a few different places online (YouTube, this forum, Crutchfield, and others), I ripped apart the console and center dash panel. I used a skinny plastic putty knife as a panel puller and it worked perfectly. $.99 at Ace Hardware.
As expected based on my research, I did have to get out the hacksaw to remove a portion of the dash support as well as to cut the plastic between the tan upper radio support screw holes and the black lower radio support screw holes.
I used the Metra 95-611 radio bracket, the Metra Axxess ASWC-1 steering wheel control module, and the Metra 40-EU10 radio antenna adapter cable. Because I didn't purchase any kind of wiring harness adapter, I did have to cut and splice each wire from the radio harness and the SWC module to the appropriate wires on the stock vehicle harness. Not a big deal thanks to the clear instructions with both the Pioneer and Metra units as well as this very handy breakdown, here:
In a moment of panic that turned into about an hour of panic, I was testing the head unit when all of a sudden my wipers came on, my gauges died, and all my idiot lights started doing funky things. I noticed a "NO BUS" error on the EVIC so I turned to Google to try and figure it out. No dice there as everything I read had no relation to my situation. Fortunately, I had the good sense to check the vehicle harness ground connector that I had tapped into to ground the SWC module. Sure enough, as soon as I touched it, my wipers shut off and the dash cluster returned to normal. Whew! All I had to do was re-adjust the connection, and tighten down the chassis bolt. I didn't take a picture of this because I was too busy being frustrated but, for those who may find this in a future search, I'm referring to the ground connector that is attached to the metal dash support on the right hand side behind the center dash panel.
When it was all said and done, the only thing I have to correct at a later date is the DODGE pocket on top of the center dash panel. Due to the increased height of the new radio, the pocket can no longer sit deep enough in the hole it goes in (as shown in the picture below). I'll correct that by trimming down the screw nubs on the bottom of the insert.
Here's the finished install. I'm using a phone holder that I bought at Walmart and routed the BT mic through the vent so that I can clip it directly to that mount.
