Plug adapter
BiGMERF
Florida
2017 SLT 4x4
v6
Ok guys need your advice. I bought the following cause according to amazons Fitment tool it would fit.
But when I go to connect it, it doesn't fit cause my plug looks like this
What am I missing ? Point me to the right one ?
lukedukem
Victoria, Tx
The one you bought plugs into the bumper. I don't know what your holding on that last pic. Is that hanging from under your truck
Luke
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
Luke
Yes sir it is. Underneath. I have the led ram sign that goes in your hitch. That I would like to hook up
AFMoulton
Nuevo Mexico
AFMoulton
Nuevo Mexico
BigMERF take a pic of your rear bumper too
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
I'm going to take a wild guess and say it goes here. I didn't notice this when I bought the truck. Truck noob problems.
AFMoulton
Nuevo Mexico
You got it brother, that harness will plug right into it
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
This is it right. It's on amazon for 21.
I don't know if could use the factory spot though, since I want to connect this
AFMoulton
Nuevo Mexico
If you want to do that and pull trailers get the one you just posted and the one averageguy posted then you can do both
huntergreen
op, you could always go to where ever you are going to purchase your trailer and let them hook everything up with the correct parts.
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
Just placed the order for both. Thanks. Some Zip ties and I'll be good to go
averageguy
Belleville Mi
hemi
Right. I didn't realize you were missing the plug on the bumper. I used this for my led bar under the tailgate so I could hide the wires and still use the 4 flat on the bumper, no splicing.
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
I'm just hoping all the connectors work. Still trying to figure out how the first one I got, did not fit
AFMoulton
Nuevo Mexico
Amazon was assuming you had the factory 7 blade connector
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
They look identical and look like it should fit. Lol. To the naked eye. It looked so similar I didn't try it until it was to late to return. Now I'm stuck with it.
I'm a truck newb and I am learning. Mind telling me, what connector I have ? It is not stock ?
AFMoulton
Nuevo Mexico
So you have the stock wiring harness, by not the 7 way RV plug or the 4 flat. The one you have you could use to plug into the 7 way RV connector. But will be redundant if you buy both of those adapters.
What you bought was a 7 way RV adapter to 4 way flat. That is used if your vehicle came with a 7 way RV plug but you needed it for say a U-Haul with a 4 way Flat plug. Hopefully that makes sense, its early and I'm only halfway through my first cup of coffee!
BiGMERF
BiGMERF
Florida
2017 SLT 4x4
v6
Same here [emoji102]. I'll find out tomorrow when they get here. This time I will check it right away. Instead of leaving it to an assumption and being stuck with it.
Hmm wonder if Wally World will take it in exchange for store credit.
