Rear dome light?
crazykid1994
Florida
I noticed a duvet in the headliner in my truck and it looks like it would be for a read dome light. Can anyone confirm what goes there? If it's a light I'd like to be able to get one and install it so I can light up my cab better
stimpy433
IOWA
Might just be an indent to allow for the back of the third brake light which would be right about there.....
stimpy433
IOWA
I'm an idiot.... I couldn't see the indent on my work computer screen.
crazykid1994
crazykid1994
Florida
Can anyone confirm that it's the same light as I have in the center of my express. Looks like it is. I may tap the light and add another into the back. More light the better
stimpy433
IOWA
Mine is a regular cab, might try Benny with allmoparparts.com. He should be able to figure out a part number.
crazykid1994
crazykid1994
Florida
Awesome. Thank you
duunoit
EcoDiesel
I just wish there was a separate switch to turn it on. I'd like to be able to turn it on without turning the two map lights on up front also.
wangatang
AZ
Cummins 6.7
I added one to mine. I only had the one in the center of the cab. I added the overhead console before, so this was a similar process. I used the cutout for the center overhead light as a template for the rear, and cut out the hole. I wired the lights up to the overhead console, as they used the same circuits.
