Zoodles95
- Jul 11, 2017
- 25
- 6
- 2013
- Ram 5.7
Hi All,
New Ram owner here. I should be taking delivery of this in a day or two:
It has the larger screen with back up camera. Navigation is being added (was worth the $ to me to have it activated):
What I would like to do is keep the head unit in the truck and replaced the 6 speakers with aftermarket. Rears would be 2 or 3 way and I would put tweeters in the dash and woofers in the door. Then some kind of subwoofer under the rear seat.
This is coming out of my current HHR which is being retired with the Ram coming in. The subwoofer is a bass worx box with 2 x 10" Infinity subs in it. The amp is a Kenwood running in 2 driver mode so a weird way to wire a sub:
I plan to use the amp to drive the 6 speakers (hopefully drive the tweeters and mids with a cross over or something) and then get a proper monoblock amp for the subwoofer or perhaps a subwoofer box with the built in amplifier.
Would this work? Does the headunit in this truck allow for this sort of thing with the required preouts?
Any suggestions for speakers which have worked well for some of you? Same for the subwoofer set up. Recommendations or model #s?
Thanks in advance for the help.
