Toolfreak
- Apr 12, 2012
- 4
- 0
- 2015
- 5.7 Hemi
I have a 2015 Ram with the 8.4AN HU and I want to use a relay to turn on my 2 amps & 4 other components and none of them have the ability to sense a signal from speaker input and turn on automatically so here is the question. Most of what I read about relays is I can run a wire from the battery to terminal 87 and put an inline fuse on it, terminal 85 will be the ground, and terminal 30 will go to the different components. But most of the diagrams show terminal 86 to hook to the remote wire off the HU but the 8.4AN does not have one, so what do I hook it to to run all the components. Also since the HU does not turn off and stays on does it make sense to put in a switch inline also so I can switch the remote on and off?
Thanks,
Toolfreak
Thanks,
Toolfreak
