Replacing Factory Speakers in 2014 RCSB
Two Dog
Ontario, Canada
2014 RAM RCSB Express
Good day,
I'm in the market to change all of the factory speakers in my 2014 RCSB. I have the base radio which is the 3.0 if I'm not mistaken. I believe Kicker is one of the go to brands, which is what I'm leaning towards.
I would like to keep everything as close to plug and play as possible. I'm not really an audio guy and would like to keep it simple.
I'm not sure of the the correct part #'s because I keep seeing different info as to what fits and what doesn't.
Could anyone help me out with part #'s to replace all my stock speakers (dash, both doors and behind the seats)?
Thanks and have a good one.
Edit - I listen to mostly 80s/90s metal if that makes any difference in the speaker choices
quietpeen
2021 TRX
Hellcat
the Part # for the front doors and dash is 77KICK28AB
not sure on the rear speakers - are they 6x9?
PNUTLT1
California
I have the same 2014 RCSB and I changed all my speakers to Infinity reference speakers.
I got the Plug and Play adapters needed to install them so the installation was a breeze.
Now the Music is Loud and Crisp and they do not clip at high volumes like the OEM speakers.
I recommend them and I got them from crutchfield with all the stuff needed to install them.
You need 6x9s for the back, 6.5 for the door or shallow 6x9 and the little 3" speakers for the dash.
I know everyone on here likes kicker but I think kicker is good for subwoofers only, i never thought there components where that good.
quietpeen
2021 TRX
Hellcat
the rear 6x9 Kicker Part # is 77Kick41
T
Two Dog
Ontario, Canada
Thanks guys, good info. Going to have to do a little more shopping first. the 77kick42 and 77kick41 are just shy of $500 in Canada.
Will investigate the Infinity offerings.
quietpeen
2021 TRX
Hellcat
Ouch it's about 260 for the kickers american
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
try amazon, ill second the kicker OEM speakers, i did the upgrade to those and they killed the aftermarket ones i had in my 2014...
i have seen the oem kickers on amazon for $100 a pair
quietpeen
2021 TRX
Hellcat
I've seen the rears on Amazon for 106 and the fronts with the dash speakers for a little over 150. U.S. not Canada
T
Two Dog
Ontario, Canada
Meh, over $600 on Amazon.ca. Guess I'll have to spend a little more than I was planning. Thanks again for the input.
