Anyone know if the seat sensors that are tied to the seatbelt are the same as the airbag? I'm assuming they are since they are weight based.
I dont think mine are correctly detecting weight. My Fiance can sit in my passenger seat with no seatbelt and it won't beep unless she sort of wiggles around and can trigger it.
This would be fine as the seat belt sensor is annoying but I assume its the same one for airbags so I need to get it checked.
Truck is a 17 with 2500 miles. Only issue is it doesn't seem to always do it so I'm sure when I get to the dealer the sensor will work fine. Especially when some 200lb+ dude gets in to test it.
