Txhemirt
Looking at adding a little sounds on the low end to the truck. I found an 8 inch sub but it looks like I will need to remove the cargo bin in back. Is this pretty much my only option other than something under the seat ?
I'm sure you can build a box that will wedge in there for an 8. If not, take out the tray, build the box you want then build a tray for the other side of the cab. Which sub do you have in mind?
