Soundproofing
Jackson Hudson
Is any kind of soundproofing better than others? I notice that there are several brands that are cheaper than Dyna mat extreme?
charonblk07
Calgary, Ab
F1-A forged 349ci
For the most part any of the vibration dampening materials will do the job you need with a 25% coverage. There are definitely better products out there like Second Skin's Damplifier CLD tiles but unless you're going for the best noise reduction you can get then brands like FatMat do a good enough job.
gofishn
Iowa
hemi 5.7L, 345 cu in
Only thiing is to get butyl mat, not roofing adhesive, since that stuff stinks to high heaven. I went with Stinger ROadkill and am pleased with the results. as mentioned, 25% coverage is all you need to dampen sound and vibrations . Of course, I went 100% solely because I I had enough and wanted the thermo property coverage as well.
autokraftgt
Hemi 6.1
This^^ I like Stinger Road kill...Dynamat seems to be the most expensive. As long as it is Butyl based you will be good to go. Deadener is NOT sound proofing, you're simply adding weight to the panel to deaden vibrations and resonances. 25% coverage is needed, anything more becomes deminished returns but helps.
VB712
Maxi_built
Va Beach
I got a roll of stuff for roofing at Home Depot. Worked great and I didn't have any smells.
autokraftgt
Hemi 6.1
Don't do what this guy did. Roofing panels are asphalt based, it's toxic to breath (whether you smell it or not) and let's face it....it's made for roofing.
If you put asphalt based panels inside your door, they will melt during summer months, and you will have black goop running out of your doors etc..
You guys are driving nice Ram trucks that are not cheap to buy....going cheap to save a few bucks and installing toxic roofing tiles just does not make too much sense to me. If you're going to do something, do it correctly and safely
adrianp89
Tampa Bay, FL
Soundskins looks like the future of the stuff. I plan on using it for my build.
-B-
Northshore of Boston
a few months ago I was in HD and found self stick duct noise dampers in roll form question is the is for inhabited areas can it be an alternative to the ultra over priced sound deadners
adrianp89
Tampa Bay, FL
Refer to Post #6.
charonblk07
Calgary, Ab
F1-A forged 349ci
As long as it's a 100% butyl it will be fine but don't get anything else. That stuff is also a lot thinner than the 'ultra over priced deadeners' and doesn't dampen nearly the same amount of vibration and noise that the good stuff does.
gofishn
Iowa
Stinger RKX36B Roadkill Expert Series Sound Damping Material Bulk Pack - $85, delivered to your door.
Less than 2 boxes did the entire interior of my crew cab pickup. I did not do the roof itself.
Again, that is every square inch, which is not needed, for vibration dampening , but, as stated, I wanted the insulating properties, such as they were and I already had the stuff, so why not.
If you do the 25% Rule, one box will kill a crew cab.
For $85!
There are instances where one can save money, they be be few and far between.
Most often, ya get what ya pay for.
In the end, it is your money, your truck, and your health, do what you wish.
BadHabit2Break
Houston, Tx
3.6L
I used the seal and peel stuff once, it did the job, but then after reading up on it, I thought my health was more important.
There was a video I watched where they tested the seal and peel against an actual sound deading tile and the seal and peel feel very short. i will try to find it.
autokraftgt
Hemi 6.1
I believe the test was done on DIYMA a few times...so many people were talking about seal and peel and other products that they decided to test the asphalt based roofing stuff, versus butyl based, automotive-specific sound dampener. The results were clear that asphalt-based tiles should stay on the roof of your house as intended.
