Jackson Hudson
- Jan 14, 2017
- 8
- 2
- 2012
- 5.7
Is any kind of soundproofing better than others? I notice that there are several brands that are cheaper than Dyna mat extreme?
Only thiing is to get butyl mat, not roofing adhesive, since that stuff stinks to high heaven. I went with Stinger ROadkill and am pleased with the results. as mentioned, 25% coverage is all you need to dampen sound and vibrations . Of course, I went 100% solely because I I had enough and wanted the thermo property coverage as well.
I got a roll of stuff for roofing at Home Depot. Worked great and I didn't have any smells.
a few months ago I was in HD and found self stick duct noise dampers in roll form question is the is for inhabited areas can it be an alternative to the ultra over priced sound deadners
I used the seal and peel stuff once, it did the job, but then after reading up on it, I thought my health was more important.
There was a video I watched where they tested the seal and peel against an actual sound deading tile and the seal and peel feel very short. i will try to find it.
