RAMpant1500
- Jan 10, 2016
- 32
- 3
- 2010
- 5.7
So I've got two 10" JBL subs in a custom enclosure stretching across the entire back seat, taking up both under seat storage areas. Subs are rated at 125w RMS - 500w peak @ 4 ohms. Not sure what the volume of the box is. Subs are powered by a JL JX 500/1 - rated @ 300w RMS x 1 @ 4 ohms. I didn't install everything and I'm a novice when it comes to car audio so I have a few questions. I messed with the gain and bass boost on the amp and it seems to distort pretty quickly when you turn the levels up. Is that a sub problem or amp problem? Also, since it's a single channel amp, how did they send it to 2 subs? Am I underpowering the subs or pushing them too hard?
