I have a 2014 ram sport with projectors. I did the fxr retro and mounted the morimoto ram u spec kit which has a halo and a u-bar. My truck has DRL. What I might do is tie into ignition power using a fuse tap kind of thing or maybe just have it switched since I want to switch it anyways. That way I would only have to tap into one wire which would be the signal wire. Hopefully from the back of the headlight I can access it cause I really don't want to open them up. The u spec kit has a driver for each halo and u bar with a white, yellow and black wire. White is for white light, yellow for amber and black is ground. Pretty straight forward. Thanks for all the info appreciate it. Will try to tackle it this weekend.
