Decided to install a dash cam after my trucks been hit a few times at the train station where I leave it every day. I'm having problems hard wiring it. The kit instructs you to locate a constant power fuse and an accessory fuse and wrap the corresponding wires around the leg of each fuse and reinstall the fuse. I chose the fuse marked cigar lighter as the accessory and the fuse marked trailer brake/flash as the constant. Both of which are 20A and happen to be next to each other. The camera does not turn on. Anybody have any ideas of which fuses would be best to tap into? I originally thought the power ports on the dash would be perfect. The USB port on the right of the dash stays live when the trucks off. The cigarette lighter style accessory port on the left dies when the trucks off. But I can't identify them by the descriptions in the fuse panel.
