Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Audio & Electronics
Audio & Electronics
Uconnect 8.4 aftermarket amps & subs/speaker install
This is a discussion on Uconnect 8.4 aftermarket amps & subs/speaker install within the Audio & Electronics forums, part of the 4th Gen : 2009 - Present category!
Hey guys & gals, New here to the forum, so forgive me in advance if wrong area, format etc... I'm ...
Like Tree2Likes
Reply
Old 02-03-2016, 06:52 AM   #1 (permalink)
Tinmanzroad36's Avatar
Ram Year: 2014
Engine: 6.7 Cummings
Default Uconnect 8.4 aftermarket amps & subs/speaker install
Hey guys & gals,
New here to the forum, so forgive me in advance if wrong area, format etc... I'm installing a set of amps, component door speakers and subs to my 2014 ram 2500 with uconnect and keeping factory head unit. I purchased amp kits & a LC2i output converter to tie into the factory wiring. However, this type of head unit, may be beyond my understanding of typical output, and I am having trouble with the system not working. Has anyone done this type of install and knows what type of inverter or plug-n-play module that may take all the splicing into wires out of the process for me? Thanks in advance!
Sponsored Ad
Register to remove this ad.
Tinmanzroad36 is offline   Reply With Quote
Old 02-03-2016, 08:34 AM   #2 (permalink)
Ram Year: 2013
Engine: Hemi 5.7
Default
You need a LOC that will present a load to the radio. The PAC LOC-PROs accomplish this.
Not sure if your LC2i does it. How do you have everything wired in?
adrianp89 is offline   Reply With Quote
Old 02-03-2016, 08:34 AM   #3 (permalink)
Etroze86's Avatar
Ram Year: 2011
Engine: 5.7 Hemi
Default
We need a little info from ya. First what 8.4 do you have? is it the alpine system? Next why go with the LC2i as it will really only be able to tie one amp into the system?
__________________
2011 Express 1500 Debadged, Access Cover, Diablo Intune, S&B Intake, 2/3 GF Drop, and More Watts Than I Care to Explain!!!
Quote DavidRam- "They'd look cool sitting on my TV stand... Bang & Olufson designers can kiss my ass!"
Etroze86 is offline   Reply With Quote
Old 02-03-2016, 10:07 AM   #4 (permalink)
Graygoose's Avatar
Ram Year: 2015 Silver CC
Engine: 5.7 Hemi
Default
Some amps don't need an LOC. What brand are you using?
__________________
2015 Silver CrewCab Bighorn-Retroshop LED tails-Moto Metal-Nitto Terra Grapplers-Kicker Sound System-Bedrug-Extang Trifecta-MGP Caliper covers-Moe's 5" chrome tips
Graygoose is offline   Reply With Quote
Old 02-03-2016, 10:18 AM   #5 (permalink)
Ram Year: 2013
Engine: Hemi 5.7
Default
Can the Kicker amps simulate the resistance load for the Chrysler's that need it?
Old 02-03-2016, 11:42 AM   #6 (permalink)
Ram Year: 2015 Laramie
Engine: Hemi 5.7
Default
most if not all amps that offer the high level input dont have the load resistance built into it.
baum is offline   Reply With Quote
Old 02-03-2016, 12:15 PM   #7 (permalink)
Ram Year: 2013
Engine: Hemi 5.7
Default
That's what I thought... I don't think I have ever even used the hi-level on amp before. .
Old 02-03-2016, 12:47 PM   #8 (permalink)
wsutard1's Avatar
Ram Year: 2014
Engine: HEMI 5.7
Default
I would recomend returning the LC2i and going with the LCQ-1. The LCQ will allow you multi channel output so you can run mutiple amps.
Additionally, the equalization of the LCQ is very much needed in these trucks. The factory radios are set to pump up the high end to levels that really suck when you upgrade your system. Which is also why I would advise the LCQ even if your amps take line level input.
If you don't have the Alpine system then this might work for you.
Signal:
1. Identify the speaker outputs at the head unit harness and cut them. If you are using the LC2 then only cut the front. If you are using the LCQ then cut the front and rear.
2. Leave as much wire as possible on the harness side in case you need to reconnect them later.
3. Connect the harness side of the cuts to new wire and run that to wherever your Audio Control is located. Some prefer soldiering, some ue butt connectors, I personally like Posi-Lock connectors.
4. These will be your line level inputs the Audio Control will use.
Power for Audio Controls:
1. Two options, tap into an existing power source like the AUX power in the center console. or, use the power you are running to your amps. Both ways work.
2. Make sure you properly ground the unit. Easiest place it to use the ground your amps are using.
Obviously run the RCAs to the amps.
This should be it.
wsutard1 is offline   Reply With Quote
Old 02-03-2016, 04:56 PM   #9 (permalink)
Graygoose's Avatar
Engine: 5.7 Hemi
Default
we do a lot, less chance of added noise.
__________________
Old 02-03-2016, 08:25 PM   #10 (permalink)
Ram Year: 2014
Default
I wired in the LC2i behind the head unit, splicing into the outgoing rear +/- wires. When I turn everything on, the subs barely come on, and the door speakers come on but drop out as soon as I start turning up the sound.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
speakers, subs and amps questions Bebeau45 Audio & Electronics 3 01-27-2016 07:53 AM
Looking to install some subs n my truck. Smallblock421 Audio & Electronics 3 10-22-2014 09:27 PM
speaker and amp install with aftermarket HU RAMthevbied Audio & Electronics 5 08-14-2014 02:13 PM
2013 Speaker/Amp/Subs Build wcthattan Audio & Electronics 29 06-25-2013 08:38 AM
Is it possible to hook up Amp/Subs to Uconnect 8.4 RA3 system? HowiesHemi Audio & Electronics 3 06-12-2013 01:50 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
