Venomous
Hi All,
Upgraded the radio in my 2016 Ram 1500 to the Uconnect 8.4AN VP4 NA from the Uconnect 8.4A VP3 NA. Everything is working great except the SiriusXM. It never finds the sat signal. GPS NAV works perfectly.
Reset using Engineering Mode. Still have SiriusXM problem. While engine is running I unplugged Sirius / GPS antenna. Screen goes from Acquiring Signal to Sirius Antenna not found , Please See Dealer. Plug it back in and it finds the Sirius Antenna and goes back to Acquiring Signal. In engineering mode there is a Sirius XM tab, select it and it shows that it has found the antenna, it is Acquiring a Signal, Satelite Signal = None
Put the original Uconnect 8.4A VP3 NA back in and by the time it boots, it has already found the sat signal.
Anyone have any ideas on how to fix this?
