Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Audio & Electronics
Audio & Electronics
Uconnect RA2 to RA4 upgrade assistance
This is a discussion on Uconnect RA2 to RA4 upgrade assistance within the Audio & Electronics forums, part of the 4th Gen : 2009 - Present category!
Hello Ram Forum. I am a new 2014 RAM owner that was unfortunately unable to find the truck configured how ...
Like Tree8Likes
Reply
Old 08-10-2014, 01:04 PM   #1 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default Uconnect RA2 to RA4 upgrade assistance
Hello Ram Forum. I am a new 2014 RAM owner that was unfortunately unable to find the truck configured how I wanted with the 8.4 inch touch screen. My truck came with the Uconnect 5, which isn't a bad system, but it was just not the head unit I wanted.
I have purchased the 8.4AN RA4 with the manual climate control bezel from a salvage. I did this knowing that A) the actual head unit is (mostly) plug and play and B) the climate control bezel is not "compatible".
I have read that the new radios are "not interchangeable" but I am not buying that because there are several sources that have proved otherwise. I could just drop in the 8.4 unit and live without the volume and tune controls on the bezel while using the steering wheel controls, but that's not good enough for me.
I did try that techauthority wiring diagram link elsewhere in this forum but even putting in the VIN from the truck this radio came from it still only shows the non 8.4 wiring best I can tell. Clearly there is a missing link and I really hope to find a way to make it work.
So here is my dilemma. I need to know what the trucks with the 8.4 screen climate control wiring harness looks like. It is my hope that someone with knowledge or would be willing to offer assistance with some pictures might be able to get me further along. What I cannot determine at this point is whether there is a module that plugs into the climate control 24 pin connector and then a bridge to plug into the 8 pin bezel, or if the wiring harness itself is different.
Thank you in advance.
Sponsored Ad
Register to remove this ad.
aqualite75 is offline   Reply With Quote
Old 08-10-2014, 01:44 PM   #2 (permalink)
jeepguy_1980's Avatar
Ram Year: 2013
Engine: 5.7L
Default
I can physically make a harness to connect to the new bezel. However, I do not know if it will work without a BCM flash.
Sent from my HTC6525LVW using Tapatalk
__________________
RIP
jeepguy_1980 is offline   Reply With Quote
Old 08-10-2014, 02:01 PM   #3 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Here are the images of the climate control wiring harness connector along with the back of the Uconnect 5 RA2 climate control bezel and the Uconnect 8.4 RA3/4 manual climate control bezel.
climate_wiring_harness_2_.jpg   uconnect_5_manual_bezel_2_.jpg   uconnect_8.4_manual_bezel_2_.jpg
Old 08-10-2014, 02:02 PM   #4 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Oh? I would be interested. A BCM flash, is that something I could get the dealer to do? What would it involve?
Old 08-10-2014, 02:08 PM   #5 (permalink)
Ram Year: 2013
Engine: 5.7L
Default
It's not something the dealer can do easily. If a BCM flash is required, you will need to get your dealer to email Chrysler engineering, and have them add the appropriate sales codes to your VIN. Then the dealer can re-flash your BCM. I've only successfully seen this done once.
All that said, I've seen someone successfully upgrade their radio to the 8.4. The only issue they had, was that the volume knob would not work. If feel fairly confident that this can be fixed without a BCM flash, but I cannot be certain.
__________________
RIP
Old 08-10-2014, 02:12 PM   #6 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Good information to know. Very much appreciated.
Are you familiar with the wiring? Is there in fact a different wire harness for climate control? Before I started on this I spoke with my dealers parts department and they didn't think there would be a problem with the actual wiring. Of course they also stood by the fact that this could not be done but that's another story.
Old 08-10-2014, 02:25 PM   #7 (permalink)
Ram Year: 2013
Engine: 5.7L
Default
Send me your VIN. I'll check on the wiring later today.
__________________
RIP
Old 08-10-2014, 02:27 PM   #8 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
PM Sent. Thank you much!
Old 08-12-2014, 12:29 AM   #9 (permalink)
Ram Year: 2013
Engine: Hemi 5.7
Default
Interested in how this works out. It may be an uograde I look into if you get this too work.
__________________
2013 Ram 1500 Crewcab Bighorn Edition - Mineral Grey
2.5" Mopar Leveling Kit, Top Gun Customz 3/4" rear spacer, 275/65R20 Nitto Terra Grapplers, 35% Tint, Bestop Powerboards, Weathertech's, OEM Fender Flares, Catch Can (sold), S&B Intake (sold), 18" Mufflex/Magnaflow (sold)
Koko is offline   Reply With Quote
Old 08-13-2014, 08:45 PM   #10 (permalink)
Ram Year: 2014 Dodge Ram Black Express
Engine: 5.7
Default
What's the difference between the RA4 and VP4? From what I've read before, the RA4 wouldn't work unless you had the volume controls on the steering wheel. From looking at a VP4, it comes with the volume controls on the bezel already.
Would this work on a RAM?
Iczer is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
UConnect upgrade jabaniz Audio & Electronics 1 07-26-2014 11:26 AM
2013 Uconnect 8.4a (RA3) Nav Upgrade bdkramer42 Audio & Electronics 26 01-28-2014 11:16 AM
Uconnect 8.4AN upgrade El Ram Audio & Electronics 0 08-21-2013 10:52 PM
2013 Uconnect 3.0 stereo upgrade to aftermarket. Gtikid98 Audio & Electronics 12 07-07-2013 08:45 AM
Upgrade from 130 to Uconnect 430 clamps Audio & Electronics 23 02-26-2013 08:41 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
