I own 2014 RAM 1500 that is equipped with satellite/GPS antenna that is located at the drivers side in the rear. I would like to upgrade it to Cell/ SDARS antenna and install the rearview mirror with ASSIST/911 buttons. Does anyone know if that's doable and what would I need? Do you have to relocate the CELL/SDARS antenna to the front or can you use the same hole in the roof in the back of the car?
It is doable and here are the part numbers:
911/Assist Mirror: - 68096091AF
Antenna Cable Body Cell & SDARS "QUAD/CREW": - 68148279AD
Antenna Jumper Cable: - 68148258AD
Shark Fin Antenna: - 5091278AC
However, The "Assist" button will do nothing for you being your truck didn't come with it and for the 911 button to work, you need to upgrade to the 8.4A/N radio.
Enjoy! So the only gain you get is auto dim and 911 if you have the 8.4 Radio. For the cost.. its not worth it IMO.. but its your money so its up to you.
