Voicemail Problems with Uconnect 430N
Allstar
Arkansas
2012 Sport CC
Is there a trick to hearing your voicemail messages through the Uconnect using Iphone 4S? I ain't figured it out yet.. Thanks
LB3711
Trumbull, CT
3.6L V6
don't know I haven't tried. I'll have to check that out next time im in my truck. I have the 430 which is pretty much the same without nav
A
Allstar
Arkansas
2012 Sport CC
Yep, I can't listen to my VM's when connected to BT and the phone won't alert when I receive a text. It will vibrate, but no audio alert. To listen to the VM's, I have to disconnect the BT then reconnect..
A
Allstar
Arkansas
2012 Sport CC
Update: Service department says can't do these things through uconnect at this time. To listen to VM's you have to call your voicemail via phone number at this time...:mad:
