mhb1638
- Oct 1, 2013
- 766
- 248
- Savannah, Georgia
- 2019
- Hemi 5.7
Have some questions about installing an amp. I am considering installing a 5 channel amp (Kicker 43CXA6005) along with Audiocontrol lc7i to clean up the signal. I currently have the kx400.4 Kicker amp but was thinking about going 5 channel instead.
Questions:
1- if I went 5 channel, I will be running high level to the lc7i. Then 3 outputs to the amp. I'm wondering, with no 3rd input for the sub (unless I tapped off a speaker wire like it is now) will I get any output for the sub?
2 - trickier thought - if I stay with the 4 channel amp...again, no signal input for the sub. If I used some sort of rca to hi level piece, can i run that back to the VSS amp?
Just trying to get the cleaning sound possible at this point. Very very unhappy with my radio sound. I mainly just drive around with it off. The radio is being replaced Monday but I doubt that'll fix anything. Thoughts?
Questions:
